Question about Ricoh Aficio 1515MF All-In-One Laser Printer
I have several of these ricoh 1515 copiers all working fine and then posting a need photocunductor error. Is this some preset error that comes after so many copies like HP got sued for or is the photocunductor actually bad ? Seems suspicious to me. Is there a way to reset the counter so this thing will go back to working until the part really needs to be changed ?
    New Friend:
Enter service mode as follows:
"Clear Modes"
" 1, 0, 7 "
then hold "Clear/Stop" for 2-3 seconds. 1 Copy SP
5 Mode
912 PCU ALARM COUNTER
Default 60K or 45K just input Zero "0" this will deactivate the PCU counter.
Posted on Feb 06, 2013
  • selimcayir
    selimcayir Feb 06, 2013
    enter service mode as follows:
    "Clear Modes"
    " 1, 0, 7 "
    5 Mode
  • 904 Answers
Hi, the "Replace Photoconductor" message does come up after a preset number of copies, typically about 60,000. The photoconductor will still continue to work fine, and even with the message displayed the copier should run like normal. The message will keep flashing until you replace the photoconductor, and then it will automatically detect the new unit and the message will disappear.
Posted on Jan 25, 2011
Ricoh Oficio 1515 tengo el eror SC 541
Fusing thermistor open error
Symptom: The fusing temperature remains lower
than the specified temperature by 20
degrees Celsius.
Possible Cause:
• Defective thermistor
• Incorrect installation of the thermistor
• Defective power supply unit
• Loose connectors
Dec 04, 2010 | Ricoh Aficio 1515 All-In-One Laser Printer
Needed to have machine reset and now I lost my scanner
Do a Google-search for "Ricoh Aficio 1515 Printer downloads".
Select and download and install the software-drivers for your printer.
Jul 22, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh 1515 scanning direct to emails
you will need the copier hooked to a network and able to get out to the internet. You will need a email account like comcast.mail.net and password if your mail server has authetication. On the ricoh go to USER TOOLS buttom choose SYSTEM SETTINGS - FILE TRANSFER-SMTP and enter the setting there good luck
Jun 27, 2008 | Ricoh Aficio 1515 All-In-One Laser Printer
Printer Ricoh Aficio 1515
delete drivers and reload, make sure you're using PCL 5 drivers.
Aug 14, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
578 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
