Panasonic Lumix DMC-LC33 Digital Camera Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the largest memory card I can use with this camera? Is 16g too large? I get a memory card error message when I put one in and I cannot format it.
Andy
Level 1:
  • Contributor 262 Answers
  • Posted on Jan 21, 2011
Andy
Contributor
Level 1:
Answers
262
Questions
0
Helped
56702
Points
28
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Panasonic Master 102,366 Answers
Panasonic Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10425658
Points
622693
According to the manual, the DCM-LC33 uses MMC and SD cards. Your 16GB card is actually an SDHC card and will not work. SD cards max out at 2GB.
What is the largest memory card I can use with this camera panasonic DMC-FX9? Is 8GB too large, because this 8GB is give me memory card error. pls what can i do???
This a camera with some years, be aware of that - that camera comes with an 16Mb card...
Try to format the card on the camera;
Also, some brands or models are incompatible - try to use other card and/or other capacity;
Always format the card on your camera.
Hope that helps, good luck.
Camera message is: memory card requires formatting : I chose the option to format and camera will start formatting then stops and this message pops up:please format memory card or put in new memory card. I...
Try formatting through the computer rather than from within the camera itself. Or, just open the card on the computer, select all, then delete. There's probably a large file in there somewhere that the camera just doesn't have enough ooomphh to move out.
Hope this helps. :)
Sep 29, 2010 • Cameras
4helpful
I just bought a new memory card (8gb) for my digital camera (Samsung NV10) and when I inserted the memory card, I kept getting "Card Error". It said I should format the new memory card and I tried to...
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
2helpful
2answers
Put a new 4gig card in as I lost the old 1
I verified that I cannot format my 4 GB cards in the Coolpix 5700. This camera simply cannot use large memory cards. You should get a 1 GB card for this camera (I verified that 1 GB cards do work).
On screen it says memory card error please check the card. i have put 2 cards in with same result photos go to internal memory and wont take photos with card in slot
Make sure the cards are 2GB or less, 2GB is the largest the camera can support. If they are, you may need to format the cards to use with the camera. Press Menu/Set to display the PLAY mode menu and select the item to set. Select Format and confirm by select Yes. The owner's manual says to perform this procedure when you get MEMORY CARD ERROR.
Reformat of XD card - comes up with card error
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
As far as the 128mb card is concerned if it gets a card error message try cleaning off the gold contacts on the back of the card and reinserting it to the camera. If it still gives an error it may be a problem with the internal card reader in the camera.
1helpful
Olympus c150 camera put new memory card in getting message card set up format power off then mesage erasing all help please i have a C-170 camera, when I turn it on, 2 options are given power off and...
The problem is that the largest xD card that your camera can support is a 256mb card. The M or H 256mb cards are not compatible. The firmware in the camera cannot support memory storage of that type. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
2helpful
2answers
The largest memory card capacity of the Kodak Easyshare C330?
its not the card! all cameras do not read all the same ds cards...even tgough they may all fit I recomend a sandisk card!
Card error when i put new xd card into my camedia c-450 zoom it wont format, comes up with card error message (using olympus 1gb xd card.)
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb card is not compatible.
3helpful
3answers
Unable to format memory card
You mentioned in your post "the above camera", but I can't find the make/model of your camera? Check on the manufacturer's website to see what the largest capacity card can be used in your camera. Knowing the make/model and searching for the message on the internet can yield better answers to your question.
If this satisfies your question, please rate it FixYa!
Nov 27, 2007 • Cameras
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
