Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx  USB Logo
A
Anonymous Posted on Jan 21, 2011
How do I attach power amp to 1832 mixer - Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx USB
Sound-Pro
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 22, 2011
Sound-Pro
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1560
Points
8
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
1helpful
Hi i have a KAM Powerhead 100w mixer amp. It has 4 channels and a usb port for Ipods etc. It powers up fine but when i plug my passive speakers in ( the cables are 1/4 jack brand new) i get no sound. Also...
on most mixers, there is a master control slider..if its on zero you wont get anything..raise it slowly to a desired level..it should have something then if not take it to a music store and let them educate you on how and where most things are and what they do..they can help you with its operation..
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
What do you hook up first, mixer or power amp oreffects in a rack system?
Effects plug into mixer, mixer plugs into power amp. Others may want the mixer and the effects plugged into the power amp for the most available inputs. (when multiple inputs are available.)
Effects and mixer are a line level output and the mixer can be considered a line level input as well. A mic mixer has gain amplifiers for the inputs that are below line level such as unamplied microphones. It is possible to parse to absurdity, but the gist of it is above assuming you do not want to apply the same effects to everything all at once.
1helpful
2answers
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
I cant figure out how to connect my xenyx 1832 fx to my desk top computer
alcuni canali non funzionano metto il microfono e non va lo metto in un altro canale funziona come mai? salve e grazie gioago 1
My macbook pro will not identify the usb mixer. it said the mixer would work with a mac or pc, so what can i do to make them compatible?
hello, I have a behringer 1832. the issue I have is that the right channel is out all together. both subs work. it is only the right main. do these things have some sort of mono switch that I don't know about?
I cant get any output in sonar 6 ahd yes the rack is active im new to sonar just the mixer xenyx xl 1832 usb
Make sure Sonar is set to use the Xenyx for the clock in the audio options pull down menu. It often defaults to your PC soundboard.
I need the part number for the volume slider on a 1832 fx mixer p
I don't think you require a part number for your mixer, ring the company and tell them what model you have and I'm sure they will be able to assist you in regards to your volume slider.
regards Col
How do i set a behringa 1832 fx mixer
I have a behringer 1832fx mixer and have the manual that illustrates how to set up for a band and/or other instruments etc! is this is what your asking for?
regards Col
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
