I have a Panasonic Lumix DMC-FX150. How do I transfer pictures from the internal memory onto the memory card? i have an empty card- cannot get any menu for transfering only deleting
thanks
Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Move the internal pictures to your card and then switch it to record to the card...
Here is a tip that may help you with your problem....
I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer... The process for your camera may not be exactly the same, but should be similar.
Your card is probably good. Go into the camera's setup menu and find the picture storage or memory section. Select external memory as default and you should be good to go.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Yes. There's a "Copy" option in the playback menu. It can copy all pictures from internal memory to a card, or individual pictures from a card to internal memory.
This should help
Press [ menu set] to display the [PLAY] mode
menu and select the item to set.
You can copy recorded picture data from
the built-in memory to a card or vice versa.
1 Press up/down to select the copy
destination: (in to card) and then press
[MENU/SET].
When you remove the card, can you review the pictures that are on the internal memory? If you can and you want to save them, download them to your computer. Then, with the memory card still out of the camera, format the internal memory.
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
