Question about Kodak Easyshare M753 Digital Camera
Mine too mine is a kodak easyshare C330 and when i plug it it it won;t charge or turn on! please help im begging im taking it to camp in 2 weeks do i need a pro- help or is there an easy way (it uses AA battery 2)
  • 2,517 Answers
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Posted on Jan 22, 2011
  • lizzyluvssch Jan 22, 2011
    um yes hello its me umm i said its a easy share C330 not an Easyshare M753
    please help i also have a kodak not sure what it is but its read thin and it says it has 10.3 mega pixels and 33mm-96mm (Equiv)
6ya staff
SOURCE:
Kodak camera easyshare C330
Try removing the memory card and the battery
Then power on the camera w/o the memory card
Then if the same problem persist try formatting the internal memory
If Problem Still persist you could call 1 800 235 6325 op 12 then op 2 your camera might be needing repair
Aug 20, 2009 | Kodak EasyShare C330 Digital Camera
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare C330 Internal Memory Full
i went to kodak and looked it all up . thanks for everything again ,cowboy14509
Apr 05, 2009 | Kodak EasyShare C330 Digital Camera
Got filesys erroe e00100 on c330 kodak. Went and got new 1gb sd card have same problem. Kodak will not support their camera. Please help.
Is the write protection switch enabled?
Which firmware is installed in the camera?
Try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Mar 17, 2009 | Kodak EasyShare C330 Digital Camera
FILESYS ERROR E00100
Which size has the card?
Is the write protection enabled?
Click
But try an firmware upgrade.
Dec 20, 2008 | Kodak EasyShare C330 Digital Camera
I have the kodak easyshare c330 I just bought a kodak memory card 2gb the camera is stating that the memory card is full can you help me with this?
the c330 can only take memory cards up to 1 GB SD memory cards. This camera was manufactured when the 2 GB was not yet made. Your camera will not work with a 2 GB
Dec 02, 2008 | Kodak EasyShare C330 Digital Camera
Why is the camera stating memory card is full?
Hello, I have the same camera, I went to buy a Kodak memory card and the Representative was kind enough to ask me what digital camera, he said that the c330 will only take a 1GB SD Memory Card. Hope that helps.
Hello i have the kodak easyshare c330 digital camera . i just purchase a kodak sd 2gb memory card the camera is stateing that the memory card is full can you help me with this problem please
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
New memory card says memory card full
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
Jul 29, 2008 | Kodak EasyShare C330 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
158 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
