SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
SOURCE: Older 6 burner wolf commercial range ignition problem.
If it were the gas regulator, existing flames would go down as more burners are turned on.
There are set screws on the pilot fittings that come out of the manifold, you could try turning those Counter-clockwise to turn the pilots up. (Don't loosen them all the way, they will fall out!) If that doesn't work chances are the pilot stems will have to be replaced to get a higher pilot flame.
SOURCE: new gas range converted to propane
I think it sounds like one of two problems either the wrong orifaces were installed in the gas valves for the conversion or the pressure on the output side of the gas valve was not set correctly.
SOURCE: Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
SOURCE: whirlpool electric range burner exploded ''on'' light on always
Hi There,
While the stove is unplugged remove the bad burner from the stove and set the bad burner's control knob to the "OFF" position. Now plug the stove back in. If there is a problem it should trigger the breaker and shut off the stove. If you are not comfortable doing this you might want to ask someone.
The explosion was due to a shorted burner element and once it is removed there shouldn't be any more problems. I hope this was helpful and I hope you get your stove going again.
