You have a bad break master cylinder seal. replace master cylinder unless you have the expeirence to rebuild master cylinder
The seal around the piston on your master cylinder is leaking. You need to replace it not just for cleanliness, but more for safety. With it leaking, you are losing fluid that is supposed to be going to the brakes. Your brakes will eventually faiil if you don't fix this soon
