Hola tengo en mi taller un televisor samsumg modelo hc p4752w que en la pantalla presenta una imagen no llena y tipo obalada de los lados le falta voltaje como del horizontal y revice y no encuentro el problema alguna sugerencia por favor muchas gracias
Pico Fuses are either Green or Yellow ,they are in many different circuits near STKs,and Startup Power Supply boards.
Encompass Parts Distribution sells Parts and Boards for this Model.
Most of the time their is 2 resistors that need to be replaced 3.9ohms located in front of ICs.
First just replace the ICs ,you might not need to do anything else.
