I'm not sure about easy photoprint ex,but the version before that only supports jpegs.If its a .bmp or .tif it won't even show up in the pictures.Also make sure there named...such as xxxxxx.jpg,with the .jpg or it won't print those either.hope this helps.I myself am looking for a way to use easy-photoprint with a brother printer.Allan
Mac OS X v10.5 Compatibility
For Mac OS X v10.5 compatibility, see below:
<Supported models>
BJC-2100,
BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D,
i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960,
i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP2600, iP3000, iP3300,
iP3500, iP4000, iP4000R, iP4200, iP4300, iP4500, iP5000, iP5200,
iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500,
iP90, iP90v, mini260, mini320, Pro9000, Pro9500, S200, S300, S330,
S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D,
S830D, S900, S9000
<Supported software>
- Printer driver
- Memory Card Utility
- Network Tool
- Setup Utility
- Easy-PhotoPrint
- Easy-PhotoPrint Pro
- Color Management Tool Pro
- Easy-PhotoPrint EX
<Usage>
To use with Mac OS X v10.5, download the latest version of the software from the Canon Web site.
For Easy-PhotoPrint and Easy-PhotoPrint Pro, use the counter-measured version available for download.
The following models, the printer driver is included in the OS.
BJC-2100,
i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP3000, iP3300, iP4000,
iP4000R, iP4200, iP4300, iP5000, iP5200, iP5200R, iP6000D, iP6210D,
iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260,
Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D,
S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
Thank you shinemicheal for your help - but I have already downloaded the easy-photoprint ex (which seemed to be the only compatible software for Mac OS X v10.5 available) from the canon web site. I have been able to print some photos but not others, which remain greyed out. I was hoping if not to be able to solve the actual problem a problem shooting link might be suggested? I will return to canon web site and try to get other version you suggested.
