Tannoy Fusion TS10 Speaker Logo
Posted on Jan 23, 2011
My Tannoy TS8 seems to have no power getting to it. I've changed the fuse in the plug but no joy. Any ideas?
2 Related Answers
Anonymous
  • Posted on Apr 18, 2009
SOURCE: Power Problem Tannoy TS10
Have you checked the power supply. Maybe it has died.
berggei
  • 65 Answers
  • Posted on Jan 19, 2016
Check the bipolar capasitor C100 on power amp module. Also Check C101 on same module.
One of my Tannoy R1 speakers fell from about 6 feet high. It landed on its side flat, didn’t really bounce. I hooked it up again, and yeah, sounded like it was at half power and was fuzzy. Looking inside...
The speakers consist of an induction coil, and a magnet attached to the cone. You have damaged something internally or the cone itself. Speakers don't have fuses unless they are powered speakers with mains input and an amplifier. You need the speaker repaired or replaced.
Contact the maker
https://www.tannoy.com/service.html
Specs
https://www.ebay.com/p/78039939
My sanitop is not working. i've changed the fuse but no joy. can the motor be burnt as it may have been on for a while since my son left the tap running
If anything goes wrong with the unit it usually happens in the pressure chamber, the motors are very durable, any part in there can be replaced. Im thinking the capacitor might have seized up and will probably need to be replaced.
1helpful
The multi tool has stopped working, there seems to be no power, I;ve changed the fuse. still not working
THE PLUG MAY BE BAD OR THE CORD. IF YOU CHANGED THE FUSE, YOU SHOULD BE ABLE TO TEST FOR POWER,AT OR AROUND THE FUSE..THIS WILL TELL YOU IF THE CORD IS BAD.. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA
Jun 20, 2011 • Garden
Came home and there was no power to my Logitech z-5500 speakers. Have changed fuse and power cable, still no joy any ideas
i have this same problem, i dno what the heck happend to my speakers. i tries changing the fuse in the plug, and also the timer fuse in the sub itself... stil no fix... im still getting no power to any of the units... the standby light doesnt even come on.
My Tannoy TS10 keeps blowing fuses and I get no power signal on the LED
Something inside it is acting like it was just a piece of wire instead of doing it's job. That's why the fuses blow. Look at either the power supply section - transformer, diodes, voltage regulators. OR the main output devices. If they are transistors, you can test them with a ohm meter. The part will show up easy! It will be just like you had just touched the two probes together!!
Hi There, My Tannoy Saturn sub stopped working, no audio, function lights still work but nothing from speaker not even background hum except for loudish crackle when power first switched on. any ideas?...
ho i got a AS that did that im NOT saying it will work with yours but if you open it up and replace the fuses with new ones it should work i reakon you have blown the sound fuses and not the power fuse hope it helps m8 and like i said it might NOT work
2answers
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
