I have a kenmore 90 series, while filling..it's all hot and very little cold. I've checked the outside lines and their clear. So now I'm going inside, any thoughts?
ended up being the solenoid for the hot water, easy fix thanx. this site's a wealth of info!ended up being the solenoid for the hot water, easy fix thanx. this site's a wealth of info!
You can't post conmments that contain an email address.
if it will just not fill try it on warm rinse if water comes in hot the water valve on the cold side could be plugge usualy repaired by removing the hose and screen and cleaning if the screen is clean you may need a new valve.
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
You can shut off the water, then remove the hoses to see if the screens on the fill valve are gunked up. This is much easier to do than to replace the valve. I think you'll have sucess on that route :)
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
