If you can take the board out of this TV, you will find many bad solder grounds. First places to look for, are the vertical IC and the horizontal transformer. Be sure to check the solder connections on the small board connected to the picture tube. Very common problem for any and all these tube type TVs. If the vertical IC has bad grounds it would be in your best interest to replace the capacitors near and next to this IC. In any case resolder any and all bad solder connections. Your picture will return in most cases. Thanks for asking and show a few hands of support.
