there is a way to reset your phone and reflash your firmware with flashloader 7.7.xA turn off your phone and connect to pc with a microusb cable and press VOLUME DOWN+LOCK combo while you connect your phone.. install driver and flash loader software.. press SET MODEL button select c3300_LIBRE_setting_v2.mdl and select application binary c3300KJP.ptt select c3300KOJPJl1.csc start reflashing and reconnect using the VOLUME DOWN+LOCK combo that you used in earlier step
With article and troubleshooting guide solution for LG E612 Hard Reset Google Lock
Method (1): Backup PIN & Google Account.
On the pattern locked screen, click on the "forgot pattern" button .
You will be asked to enter Backup PIN & Gmail ID & password that was being used in the phone
Phone will be unlocked once you have provided Backup PIN ,Google account ID and correct password.
Note: No user data will be erased in while resetting pattern with above method
Method (2) : Pattern unlock with hard reset.
If you do not remember Backup PIN or the Gmail ID & Password details or you has not logged in with his Gmail ID then you should perform hard reset.
Note:This method will erase all user data and settings from the phone. and process is irreversible.
Make sure phone is Powered Off.
Press & Hold the "Volume Down Key (V-)" and "Power button" altogether
As LED at the bottom of the phone lights up, Release both pressed keys (V- and Power key)
Just after releasing the keys, press & hold "Home" key for about two seconds.
The phone will turn ON & perform Factory Reset immediately.
Warning!During working on this trick if accidentally your handset may have dead or faulted. We are not responsible for that please read our privacy policy.
<span style="font-weight: bold;">Bosch Dishwasher:</span><br />
<ol>
<li>To deactivate, press and hold the "<" button until the Child Lock LED goes out.</li></ol><span style="font-weight: bold;">Bosch Microwave:</span><br />
<ol>
<li>Press "Settings" followed by the number "5" to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Bosch Washing Machine:</span><br />
<ol>
<li>To deactivate Child Lock, press the Start/Pause button and hold down for 5 seconds.</li></ol>or<br />
<ol>
<li>Press the Menu button until CHILD LOCK :ON appears in the display.</li>
<li>Press the Select button until CHILD LOCK :OFF appears in the display.</li>
<li>Press the Start/Pause button and the key symbol should disappear.<br /></li></ol><span style="font-weight: bold;">Danfoss Thermostat:</span><br /><br />
<ol>
<li>Press the control knob or button and hold it in place.</li>
<li>Turn the knob counterclockwise until you see the word "Code" appear in the display.</li>
<li>Turn the knob clockwise and select the code "0033."</li>
<li>Press on the control knob until you see an icon of a clock or a hand appear or disappear indicating that the child lock has been set or unset.</li></ol><span style="font-weight: bold;">Delonghi Microwave:</span><br />
<ol>
<li>To deactivate Child Lock, press the STOP/CLEAR key until the beep is heard.</li></ol><span style="font-weight: bold;">Delonghi Portable Air Conditioner:</span><br />
<ol>
<li>Pressing the "+" and "-" buttons on the control panel together for more than two seconds unlocks the keypad.</li></ol><span style="font-weight: bold;">Fisher & Paykel Dish Drawer:</span><br />
<ol>
<li>Disable the child lock by pressing and holding the key with a key and lock symbol printed on it until the padlock symbol disappears from the screen.</li></ol><span style="font-weight: bold;">Frigidaire Dishwasher:</span><br />
<ol>
<li>Press and hold the No Head Dry button (or the Rinse Only, Delay Start or Air Dry button depending on model) for 3 seconds.</li></ol><span style="font-weight: bold;">Frigidaire Dryer:</span><br />
<ol>
<li>Press and hold the "Control Lock" button for five seconds to release the lock.</li></ol>or<br />
<ol>
<li>Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.</li></ol><span style="font-weight: bold;">GE Dishwasher:</span><br />
<ol>
<li>Press and hold the Heated Dry button for 3 secs.</li></ol><span style="font-weight: bold;">GE Electric Stove:</span><br />
<ol>
<li>Press and hold "Lock" for three seconds to release the child lock function.</li></ol><span style="font-weight: bold;">Kenmore Dishwashers:</span><br />
<ol>
<li>Press the "Heated Dry" button, and hold for four seconds until the "Lock On" icon light turns off.</li></ol>or<br />
<ol>
<li>Hold the "Sensor Dry" or "Lock" symbol down for three seconds until the lock indicator light goes off.</li></ol><span style="font-weight: bold;">Kenmore Dryer:</span><br />
<ol>
<li>Press and hold the AUTO DRY LEVEL button for 3 seconds.</li></ol><span style="font-weight: bold;">Kenmore Microwave:</span><br />
<ol>
<li>Touch and hold Cancel for 5 seconds to deactivate the lock.</li></ol><span style="font-weight: bold;">Kenmore Range:</span><br />
<ol>
<li>Push and hold the Lock button for 10 seconds.</li></ol><span style="font-weight: bold;">Kenmore Washing Machine:</span><br />
<ol>
<li>Press and hold "Drain & Spin" for 3 seconds to release the child lock.</li></ol>or<br />
<ol>
<li>Press and hold Cancel for 10 seconds.</li></ol>or<br />
<ol>
<li>Hold the "End of Cycle" button down for 5 to 6 seconds.</li></ol>or<br />
<ol>
<li>Hold the Child Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Dishwasher:</span><br />
<ol>
<li>Press and hold Energy Saver/Dry button for 5 seconds.</li></ol>or<br />
<ol>
<li>Press and hold Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Microwave:</span><br />
<ol>
<li>Press and hold the "Cancel" or "Start" button for five seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Oven:</span><br />
<ol>
<li>Touch and hold START for 5 seconds.</li></ol><span style="font-weight: bold;">LG Dishwasher:</span><br />
<ol>
<li>Press and hold the Spray and Rinse button simultaneously for 3 seconds.</li></ol><span style="font-weight: bold;">LG Dryer:</span><br />
<ol>
<li>In models that include a rack dry, usually holding the [rack dry] button for three seconds will disable the function.</li></ol><span style="font-weight: bold;">LG Refrigerator:</span><br />
<ol>
<li>Press and hold the Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">LG TV:</span><br />
<ol>
<li>Open the menu, select lock (padlock symbol) then select lock system, then select off.</li>
<li>Press exit to exit the menu.<br /></li></ol><span style="font-weight: bold;">LG Washing Machine:</span><br />
<ol>
<li>Press and hold "Dry" & "Spin" buttons together for a few seconds. </li></ol>or<br />
<ol>
<li>Press and hold "options & select" until the light goes off.</li></ol>or<br />
<ol>
<li>Press and hold "end of cycle" for over 5 seconds.</li></ol>or<br />
<ol>
<li>Press and hold the PRE-WASH/Child Lock buttons for 3 seconds. </li></ol><span style="font-weight: bold;">Maytag Dishwasher:</span><br />
<ol>
<li>Press the Heated Dry button for three seconds.</li></ol><span style="font-weight: bold;">Maytag Microwave:</span><br />
<ol>
<li>Press and hold the "Enter/Start" button for 3 seconds</li></ol><span style="font-weight: bold;">Panasonic Microwave:</span><br />
<ol>
<li>Press "Stop/Cancel" 3 times to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Philips TV:</span><br />
<ol>
<li>Using your TV Remote, press the 'MENU' button, select FEATURES and press cursor right.</li>
<li>Press cursor up/down to select CHILD LOCK and press cursor right.</li>
<li>The screen will prompt you for PASSWORD, key in you password if known. If the password is unknown, then key in the code 0711 twice.</li>
<li>Press cursor up/down to select CHILD LOCK, press cursor right to change the status to OFF.<br /></li></ol><span style="font-weight: bold;">Samsung Dishwasher:</span><br />
<ol>
<li>Hold down the Delicate and Rinse buttons simultaneously for three 3 seconds.<br /></li></ol><span style="font-weight: bold;">Samsung Refrigerator:</span><br />
<ol>
<li>Press and hold the Ice Off/Lock button for 3 seconds.</li></ol>or<br />
<ol>
<li>Press and hold the Ice Off button for 3 seconds.</li></ol>or<br />
<ol>
<li>Press and hold the Lighting button for 3 seconds.</li></ol>or<br />
<ol>
<li>Press and hold the Child Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Dishwasher:</span><br />
<ol>
<li>Press and hold Heated Dry button for 4 secs.</li></ol><span style="font-weight: bold;">Whirlpool Dryer:</span><br />
<ol>
<li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Washing Machine:</span><br />
<ol>
Two possibilities: the better one is that some joker put the set in demo mode (which includes a flashing power light), then turned on the Key Lock feature and turned off the set.
To check for this (quoted from page 118 of the manual):
<b>
Nokia 5130 Mobile Unlock <br /></b>
<br /><br />*#06# for checking the IMEI (International Mobile Equipment Identity) for Nokia 5130 To view Week and Year of manufacture enter *#3283# [*# D A T E #] <br />The last two digits are the year. If the year is 95, the first two digits are the month. For 96 the first two digits are the week of the year. <br /><br />To view the software version on Nokia 5130 enter *#170602112302# or *#9999# <br />On newer phones, the code has been changed to *#682371158412125# <br /><br />All Nokia phones (Nokia 5130 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) <br /><br />The main code used in Nokia 5130 phones is : <br />#pw+(master code)+Y# <br />This code is able to check, activate or remove Sim card restriction (SP-lock). <br />Use the * key to get the p, + and w chars. <br />'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with. <br /><br />#pw+1234567890+1# for Provider-Lock status <br />#pw+1234567890+2# for Network-Lock status <br />#pw+1234567890+3# for Country-Lock status <br />#pw+1234567890+4# for SimCard-Lock status <br /><br /># = DOUBLE-CROSS <br />W = PRESS "*" THREE TIMES <br />P = PRESS "*" FOUR TIMES <br />+ = PRESS "*" TWO TIMES <br />MASTERCODE = 1234567890 <br />Y = NUMBER 1 TO 4 <br /><br />(master code) is a 10 digit code, based on the phones IMEI number. <br /><br />Eg. To remove restriction on lock 1 type following code: <br />#pw+(master code)+1# <br />If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code) <br />eg. To check if phone if restricted on lock 1 type the following code: <br />#pw+1234567890+1# <br /><br />Bypass the SP lock With a Nokia 16xx/21xx/31xx/51xx/81xx <br /><br />1. Insert SIM card of different provider. <br />2. Turn on the phone and press the UP VOLUME key for 3 sec. <br />Then release it and the phone says PIN CODE? <br />3. Press the "C" key. <br />4. Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#<br /><span></span>
