SOURCE: drum makes loud noise when spinning
The bearings are worn out ,it's not worth to repair , the fact that your washer is old it's going to have more problems.
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
took off the screw clamp and it had a sock in it. works great now thanks
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
SOURCE: FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
Hello James, thank you for your post!
I understand that your Frigidaire washer will start to agitate and no water will enter the drum. This could be an issue with your water valve or the control panel. I would check to make sure the water lines are opened and the connections are not restricted or damaged. If the water hoses are not damaged you may need to have a professional technician out to perform a proper diagnosis. This will help you to avoid any unnecessary part purchases. Good luck! -Matt
