Canon MP600R working on a network
Both printer and scanner worked fine.
Then
Printer working
Scanner not working
Get message
Cannot communicate with scanner for these reasons
Scanner is turned off
Scanner is disconnected
It is disconnected from Lan (If used on Lan)
Please check and try again
Scanner driver will be closed
I uninstalled and reinstalled with the same result
Printer works on network
Scanner dosn't
connect computer to network install canon color network scangear, select printer ip in this software. now you need scanning software. I'm using freekapture. place document in printer scanner. click scan button on printer.open freekapture and start scanning
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
hi, CANON PIXMA MP160 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Try turning off the windows firewall.
If that works, then add the Canon scanner app to the list of applications that are allowed through the firewall, then turn the firewall back on again.
