Toshiba 32AV502R LCD TV Logo
Anonymous Posted on Jan 25, 2011
My Toshiba 32AV502R LCD TV powers up and then immediately turns off, before the image really comes up, then cycles between on and off. All I can see is the power status LED coming on and off, the image hardly gets a chance. Is this something that could be easily fixed? Thank you very much...
CoppellTVRepair.com
Level 3:
  • Toshiba Master 778 Answers
  • Posted on Apr 05, 2013
CoppellTVRepair.com
Toshiba Master
Level 3:
Answers
778
Questions
0
Helped
396535
Points
1847
Grand Canyon Tech
Level 3:
  • Toshiba Master 3,867 Answers
  • Posted on Jan 25, 2011
Grand Canyon Tech
Toshiba Master
Level 3:
Answers
3867
Questions
Helped
1177162
Points
12717
The issue your having comes to mind as a bad power board, What happens over time is the electrolytic capacitors inside these Tv's bulge or just become un-usable.
My Toshiba 32AV502R LCD TV powers up and then - rulds2008_27.jpg Many power supplies are plagued by poor electronics components such as these and thus you have a TV with a power issue.
The best bet here is to purchase a new power board or locate the defective component and replace it. Many cases this Tv would end up beside the dumpster awaiting the next pickup date witch pollutes the environment and creates a huge in-pact.
A repair shop would be a option but you will end up with a bill of $200-$400 bucks just for a power board change out!
What a TV tech would do is bring this in and test it with other parts. A TV tech is basically a person that graduated from some post- graduate or trade school and would charge you big money to simply switch out a power supply.
Many people like myself and others have been around the electronics repair era where we fix these broken items for Penny's on a dollar.
Do this at your own risk
If you steer to the internet with this and know basic soldering skills and electronics precautions I would suggest you dig into the unit at your own risk and purchase the components that are actually effected.
You can watch my you tube video on how I basically pulled a power board out of a LCD monitor and replaced its cap's. You can aslo go to my tips on how to search for bad caps and replace them using basic soldering skill.
MY TIPS
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
What type of fuse does a Toshiba 32AV502R LCD TV use?
It is Sunday and I am not at the shop to look it up, but I am yet to see a power supply board where fuses are not marked on the board itself.
Meaning that the answer to your question is on your own board.
Also, I have very rarely seen a fuse go bad on those power boards.
It is not impossible, of course, especially if you short it out manually, but unless you did chances are the issue is something else.
Also see
http://www.coppelltvrepair.com/p/427/repair-service-for-toshiba-32av502r-intermittent-shutdown-random-shutoff-not-powering
Hope this helps!
Toshiba tv no power
I have never heard of or seen a "power down button". Unplugging the TV and holding the power button for a minute or so sometimes will do a hard reset on the TV, is that what you seen?.
On your problem, chances are there was a spike that came down the power line when your power went out and it took out at a minimum the main fuse in the TV, you can remove the back and replace that fuse on the power board and see if it comes on or blows the fuse again, if it blows then look for a bad rectifier or shorted FET transistor in the hot section.
1helpful
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Toshiba 32av502r lcd tv keeps turning on & off, will not stay on. screen is black, but the power light keeps blinking.
The power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
2answers
When power is applied Toshiba 2av502r cycles on and off contineously.
It can be that the power supply is sensing shorts circuits so it goes into turn off/turn on cycle. You need to look inside. It can be the power supply module may have failed due to bad caps.
Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=Toshiba+32AV502R+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
1helpful
2answers
With the Toshiba 32AV502R 32 in. HDTV LCD TV, can
how do you change your HD setting say 480i to 1080p...
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
