SOURCE: Frigidaire FRS26ZSH freezer leaking
Plz provide me with a e mail adres so i can foward a users manual to you for a Frigidaire FRS26ZSH.
Thanks.
Wouter....
SOURCE: serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
SOURCE: I am not getting cool air from the freezer vent -
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
SOURCE: Water in the bottom of
The defrost drain located behind the freezer back panel has gotten clogged. You will need to remove the panel to gain proper access to the defrost drain. After removing the ice build up you will have to also clear the tube using boiling water alittle at a time poured into the drain opening. this will open the tube up and gain proper flow again.
SOURCE: Frigidaire Fridge Freezer forms huge iceblock
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
