Sennheiser RS 120 Consumer Headphones Logo
Posted on Jan 25, 2011
Unit discontinued working. Is full of static, will not tune.Replaced batteries, but still does not work
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
719
Points
Instrument panel lights will not work after new battery was installed. Previously, When door was opened one could hear static noise and flickering of instrument panel lights. Battery was checked and was no...
Hi 1987 Honda Civic lihgts on instrument panel. New Battery. and replaced blower unit but lights on panel not working. I am yet to install stereo unit which was taken out by previous owner - very roughly ! Wondering if not having stereo will effect instrument panel lights. Cheers Steve
1helpful
Bushnell yardage Pro won't read distances. Short
Bushnell has discontinued service on the yp500, yp400,yp800,yp800.yp1000. Basically all the units that look like this one. They will offer you a new unit at wholesale price.
call 800.423.3537 and ask them
mtg
Battery flashes between orange and green
The rechargable batteries have life and will go bad like any other batery. The battery needs to be replaced. Some of the older units are discontinued so parts are no longer available. New nebulizers can be obtained for as cheap as $100.
3helpful
CS60 ear peice with heavy static when in use
This may be caused by a few things.
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too high. First, try lowering the volume on the telephone. If you still hear distortion, adjust the volume of the headset. The master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
4. Make sure the headset has been paired to the base.
My landline phone does not work. I tested it outside on the company's jack and the phone works. I have 3 jacks in the house and it will not work on any of them, including the one I get the internet. The...
One of the phone handsets of the Panasonic KX-TG563 trio gives me static w/ dial tone and then shuts down or it gives me the message that "System is busy/Line in use" with no dial tone. If I get closer to the base unit it seems to work but w/ alot of static. The base unit phone works good and the other handset works ok too. The battery shows fully charged however, when I take the battery out to try a reset when I put it back in the battery indicator show very low. I tried switching batteries w/ the othe hand sets it doesn't help.
Thanks
7helpful
5answers
No Manual?
Online Manual (PDF) For DW9116
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/630429-00,DW9116.pdf
Dewalt DW9116 Product Recall:
http://www.dewalt.com/us/articles/article.asp?ID=187
Remote control freeze
Hi friend have a tech check your remote it could be damage and not transmitting signals to verify that take a radio and tune into AM point the remote it press the button on the remote.you should hear some static noise like putty putty putty constantly if you do not hear that then you could say that your remote is damage.if not then have a tech look at your set the IR could be bad and needs to be replaced.good luck.
Top Sennheiser Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
