My washer was working just fine and for the past week it wont work with out the delay cycle. how do i turn the delay cycle off. i have tryed running it through, switching cycles, and turning the delay button but all that does is change the delay times.I have a kenmore HE2t
Will make a guess. Machines can stop on the last rinse because it is waiting for the fabric softener or because it is on a delay and leaves the clothes floating so they do not crease awaiting an action to say carry on.
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
if the machines are both on the same outlet i would attempt to run them on seperate outlets first to see if it improves. as time lapses breakers or gfi's can weaken and a continous amp draw esp. in the spin and the ignition stage at the same time which are the largest amp draw from either machine at any give time could be causing the issue. if this does not work you need a tech to look at it
