On something like this several test will need to be made with a volt/ohm meter & inspection of the washers control board in order to determine what the problem is. Usually on this model the "control board is the failed component. Here is a link to the control board in case you need it.
Hi
I
believe that everything else is fine rather it is the thermal fuse that is
located inside the rear panel to the exhaust duct that is bad and should be
replaced. If you want you can test this fuse for continuity and if it is bad
then it should be replaced, as it cannot be reset. If the fuse is fine then it
can be due to the control board that is bad and should be replaced.
Hope this helps...please post back for further assistance.
Daniel
