There is an O-ring up in where the Tombstone slides in. That O-ring has to be lubed (oiled)
and should be toward the rear of the gun when installing the Tombstone. Also, drop-off
in firing can be caused by lack of lube on the internal O-rings. 2 drops of oil in the inlet hole
where your bottle screws on and then dry firing to cycle the oil thru might help. You may need
to completely tear down the gun and clean and lube the internal O-rings. If you can switch to
air AKA...HPA (High Pressure Air) it will be better for internal parts and better consistency overall.
Here is your manual for reference.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
