Question about Samsung N150 (36725723009) Netbook
After install Win XP i can't change my brightness! what should i do?
  • Samsung Master
  • 1,662 Answers
Download the system drivers for your model and install them. There are twelve variations of your computer (NP-N150JlxxUS, where l is A or P and xx is 01 through 09), so you'll need to look at the label on the bottom before you can enter the number on the support page.
Posted on Jan 26, 2011
  • 424 Answers
Samsung N150 Drivers download
Good Luck
Posted on Feb 04, 2011
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 200 Answers
SOURCE: installation win xp in toshiba sattelite
ok my friend its not that easy but its always possible
fisrt just to know why u r unable to install xp because u have the HARD DISK SATA
and windows xp wont detect it because there are no definitions for SATA HDD.
so what should we do to fix this problem, you will know that by following these steps:
at the begining you need a floppy disk and floppy disk drive (i know thats not available in the new laptops, so u might need to buy one).
ok now we will need to download the SATA definitions from here:
http://www.4shared.com/file/37736514/7da1991f/raid138.html
and save it in the floppy disk (dont forget to unzip the file first).
now lets start the windows installation process (as usual).
u before you get to load the windows file there will be a prompt (in the buttom of the screen) asking you (press F6 if u need to install a third party...........) now press F6 quickly.
you will have a new screen with three options (S= specify, enter= continue or F3= exit).
now lets press S.
you will have a prompt asking you to (insert the labeled disk manufacturer ................).
lets insert the floppy disk now. and press enter
and when its asking you to select definition, select RAID driver.
and when its asking you about windows logo testing press yes.
and after finishing the definition process it will detect the HDD.
now continue installing windows as usual
enjoy XP (i know its a long story but its worth it :)
sure let me know what happened with u and for any other problems plz let me know
cheers
Posted on Aug 31, 2008
Can I change my windows 7 computer to XP with an XP disk
yes --
But you will loose all of your files and folders when you format the hard dive to install win xp
you cannot run 2 operating systems on the one hard drive unless the hard drive is partitioned ( in effect having 2 hard drives on the one disc) as it causes massive conflicts in operation
Why any one would install an out dated , unsupported operating system like win xp in place of win 7 beats me
of course if you insist in doing it you could always install and extra hard drive in the computer and run it as an extra hard drive and install the win xp on it and still retain all of your files and folders
Sep 09, 2017 | Computers & Internet
I cant istal win xp
hello,
1st go to ur bios and change SATA Mode to AHCI from IDE
then try install win xp again :D
Dec 05, 2013 | Lenovo 7479A6U - Thinkcentre M58P 7479A6U...
I have installed recently WIN XP SP3 on my samsung netbook N100. I observed the LCD gives sufficient brightness and Contrast when charger is on while with battery backup brightness & contrast...
I believe there's a setting in your control panel > power options to change the settings of the brightness and contrast depending on the source of power. it is set there to change the brightness and contrast of the LCD on how it will change once you remove the ac adapter from the laptop.
Hope this helps!
Sep 21, 2011 | Computers & Internet
HDD not detect with win xp instalations. Cannot downgrade to win xp. somebody help. im not litterate with windows 7
Before you downgrade operating system you should enter bios setup.
turn on >>> press DEL key repeatedly
On Hard drive section >>>change AHCI to IDE >>> save and exit
you can start install win xp.
Note : to upgrade to win 7 do reverse
akee.4shared.com
Aug 15, 2011 | ASUS Eee PC 1215NPU17BK Netbook
I have Toshiba Laptop L300. It does not install xp . however it easily install Window 7
Probably because you have a SATA Hard Drive. If you want to install WIN XP, you may need to change your hard drive settings. For this go to the BIOS and change to Compatible Mode or IDE or Non SATA. The Reasons that WIN 7 install with no problems is because WIN 7 has already builtIn SATA drivers on it
Nov 18, 2010 | Toshiba Computers & Internet
Windows 7 revert back to Win XP
I think that what's important is license key of your Win XP, the installer for Win XP can be downloaded from any download site now a days. If you have a friend or know someone who has the Win XP installer, you can barrow it from them or have it copied on another disc. Then use the license key that you have from your previous operating system (Win XP).
You must also make sure that the installer that you will be using is the same version that you used to have before installing Win 7. I hope this one helped in a way.
Mar 31, 2010 | Microsoft Windows XP Home Edition
Fn key not working using Win xp can't turn the brightness down on the screen. I have a Toshiba Sat Pro A300
if it is just the brightness you need turned down go into the battery settings and change the brightness there. hope this helps
Mar 16, 2010 | Toshiba Satellite A300-0CF035 Notebook
I cannot install win xp on my hp pavalion
Hello
the easiest way out is to change the bios settings so that the disk is running in native mode, search for that settings in bios then the windows XP installation should find your disks.
other way is to have a Disk drive and download the sata driver from the manufactory site.
third way is to make a new xp installation cd with the new driver.
but try the first one first. little more info about your computer should be helping me to help your more?
good luck
Sep 08, 2008 | Computers & Internet
Samsung N150 (36725723009) Netbook Logo
1,276 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
