En allumant mon photocopieuse, après 5seconde la lettre sc500 s'affiche et ne fonctionne pas
Hi, SC500: Main motor lock
A main motor lock signal is not detected for more than 500 ms after the main
motor starts to rotate, or the lock signal is not detected for more than 500 ms
during rotation after the last signal
- Possible causes -
Sc 500 means main motor lock. this is normal for high copy volume printers. check the idler gear and developer gear of the pcu it is seldom the problem. here's the part no.
B039 3062 Idler Gear - 16z
B039 3060 Development Roller Gear
if this helps pls rate
what do you mean about "lower db unit"???????
