My washer gives a troible code of F21 what is that and can i fix without taking it to a repair shop
F21 is a drain error code. You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump.
Remove the #20 torx screw out of there to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to turn counter clockwise. So after placing something underneath to catch
the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails,
screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and
you don't have any leaks. Put your panel back in and you're ready to go.
Please make sure you post a rating if this solution was helpful.
Water leaks from detergent tray.
My washer keep stopping flashes 06 F i hit cancel and than start and it will start and go for another 6 mins then its flashes the above code again and stops. I can get one load done in a day if i keep hitting the cancel, than the start button.
My duet sport presente F 19 ERROR
my washer reads f-01 after selecting a cycle
i have an f21 code as well and will try this solution, do you know anything about a d5 code?
My washer is displaying an F21 as well as a 5d. I will try the F21 solution posted but would like to know if anyone can help with the 5d. Thanks!
my washer displays f 01
keep getting f21
I had the same problem but lumpy816 SOLVED it! Thank you!
My Whirlpool Duet Sport leaks out the front corner when washing. No codes appear, still runs fine, but doesn't spin as much water out as before the leak.
when and after I put clothes in the washing machine, when I go to reg. wash then push start and hold it doesnt start but only flashes a "F" what does this mean and how do I fix this??
Thanks for your answer Lumpy816. It got us 80% of the way. However, after filling and draining the washer it still came up with the F21 error code. It turns out there was something blocking the gray accordion hose leading from the bottom of the tub to the trap and the pump. Note that there is a ball in the top of the gray hose that prevents backflow. Making sure the hose is free of debris and kinks can solve more of the F21 error code problems.
WELL I WISH I NEW ABOUT THAT TRAP I FOUND ALL KINDS OF STUFF I CANT BELEIVE IT THANKS A MILLION
Unbelieveable, there was a pair of panties stuck in there and not a lot of water, maybe 10oz. Why oh why would the owner's manual not mention this trap may need to get cleaned out and to put small items in a mesh lingerie bag.
Thank you lumpy!
The washer is leaking! I returned the 1st washer and washed 4 loads and the new one has the same problem with nothing in the pockets!! I have checked and double checked every item before putting it in the washer! I think it may have a serious defect!!! Any ideas before I throw it in the yard! I am mad!!!
After I took the above steps, it is leaking behind the "drum". Not sure what else to call it, it's the cement thing in the front, steady leak out of that. Any thoughts?
Lumpy816 you ROCK!!!!! Thank you sooooooo much!!!!!!!!!!!!!!!! You saved us a minimum $65 service call!
