Replace the main control unit under the inits top cover in the left rear top corner & inside the plastic cover if when you open the cover that protects the mainboard from water spray(if theres NO RED LED lit on the control board) then its the board that needs replacing,if it has the LED lit then run the diagnostics per the tech sheet located inside the machine and it will tell you whats actually wrong,next step is to replace the touch pad located around the selector knob on the front face of the unit
I had the same problem after loosing a damper. Turns out when the damper failed knocked out a plug in on the main panel. The LED is very hard to find when it is not on. The LED is located close to the bottom in the middle of the board.
