Toshiba Portege M205-S810 Tablet PC Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, 1. How to transfer/copy bootable XP files onto SD card and then boot up Toshiba Portege M205 from the SD card? 2. Is it possible to made an image of my Windows XP CD on SD card? Regards Tad
  • Anonymous Mar 13, 2014
    I have transferred movies and music from my hp desktop to my pandigital ereader and it seems that even the transfer was successful, I am not able to see the movies and/or music on my ereader. do I need to clear the sd card and start over, if so, how would I go about doing so?
Anonymous
Level 3:
Guru:
  • Master 679 Answers
  • Posted on Jan 27, 2011
Anonymous
Master
Level 3:
Guru:
Answers
679
Questions
Helped
168815
Points
2165
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
  • Asus Eee PC (Of course!!)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your 3epc from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
How do I transfer apps and files to ext SD card on my binatone 7inch tab 744?
To transfer apps to SD card, you will use Settings-Apps, open the selected app, then choose Move to SD Card.
If you meant copying files, then use Explorer or other software with similar functions to copy the desired files. I think you actually meant the above.
1helpful
Windows xp not start following file missing corrupt system32 confi
Restart the computer, and force it to boot from the Windows XP CD-ROM. Choose "Repair Existing Installation", and see if that fixes the problem.
It might be better to remove the disk-drive, attach it as a "slave" disk-drive in some other computer, and copy all your files onto an external disk-drive.
2answers
Black screen after windows start. tried to open in safe mode, last known config, and open windows normally, but all result to black screen. tried to reinstall windows xp, but no progress during...
It could be the drive failed, can you boot to BIOS at all? I'd recommend a USB Drive adapter, then pull the drive from the laptop, connect to the adapter and then plug into a working PC USB port (Be sure that PC has good/current antivirus and firewall software and it has been backed up itself). The disk should then come up and look like a regular flash drive. Recover the critical files, then back up onto something like a CD or DVD that is set aside for safe keeping. Now you can be a bit more adventurous - potentially the BIOS settings changed, or the on board battery is dead and needs changing (can be complicated). There are also bootable drive recovery utilities that you can spin onto a CD. But data recovery is always first.
6helpful
How to I sync my ebooks to my cruz reader
The easiest way, if you don't have CruzSync on your computer, is with an SD card. Copy the files onto it then put the SD card in your Cruz. Then open Astro from the home screen and find your new SD card and open that up. Or you can use the cradle to transfer files. Open one internal browser to the cruz and one to your e-books then copy and paste them over. You'll fill up your internal memory pretty quickly this way, though.
Blue screen "unmountable_boot_volume" on toshiba portege 3505...only get error when battery is in laptop...can't turn on laptop at all when battery is not in laptop...help!
try to boot to windows xp or dos command, for winXP go to recovery console-select your windows-type the admin password then if C:\WINDOWS come up type chkdsk /r if that doesnt help, repair your operating system or backup your files and reinstall your operating system.
2answers
Usb cd rom will not boot can i boot from sd card
yes you must change the boot order and activate the legacy USB support if exsisted
I need help...
Right. When you try to boot into normal Windows or Safe Mode Windows, you should remover any device from your pc.
Well, here is a guide on how to make a USB flash drive bootable.
http://www.bootdisk.com/pendrive.htm
1helpful
2answers
Boot up problem
NOTE: Ususally when computers DO NOT find any startup information on the SELECTED DRIVE (like when you click a key) it goes to the default drive.
WHICH IS YOUR HARD DRIVE.
Meaning it is probably your Harddrive is broken, or your connection from hard drive to motherboard is broken
Burn a Live CD bootdisk of some linux distribution
liek Slax, google it.
Burn it to a bootable CD and put it into your drive, then select to boot from it.
If it boots only using your CD ROM drive, if that works then its probably not your BIOS/rest of computer, which is good.
And while in the live cd, you can see your harddrive and see files, that means its not broken its just your connection to it....either way im guessing youll have to send it in.
1helpful
2answers
After a hard drive falure I need to install windows xp
At this moment I have taken the HDD out of the case, bought an adapter for its 1.8" interfce and proceeded over the USB. I was, however, installing Linux, with practically no experience with Windows.
2answers
Bootable cd / dvd
one possible way around is to copy the entire cd (make a new folder named "CD COPY" or similar) to your hard drive (assuming you have enough space...about 800 Mb), then run the install from setup.exe from the hard drive, then delete the copy (to make room) when you are done.
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
