Question about Gateway MX6448 Notebook
Worked ok last night. We think the power was unplugged all night, and ran the battery down. Now, when we press the power button, the battery light flashes red four times. That is all that happens. Went to Gateway support - they said take out the battery, disconnect power, hit power button for 15 seconds, then reconnect power & try again. Did so, no change. If battery is not in, but power is connected, get nothing, no red flashing light, nothing. Put battery back in, get four red flashes on the battery light, then nothing.
  • 10,319 Answers
I have the same problem with the same model as yours 4 flashes means the mother board is fried ad eeds to be replaced
Posted on Oct 18, 2012
    New Friend:
    Problem Solver:
  • 6 Answers
Sounds like your power cord is no good.
Posted on Jan 27, 2011
6ya staff
SOURCE:
Laptop will not start up
Try holding power button down for 10-15 seconds
Mar 02, 2015 | Computers & Internet
My LG 4G LTE won't turn on even though it has been charging for hours.
do you have a universal travel charger? and use it to charge your battery for about 4 hours. or buy a new battery.If it is not ok, your phone is in short-circuit. go to service center
Apr 15, 2013 | LG Cell Phones
My Gateway M-6750 laptop was working last night but today when I tried to turn it on the power button light flashes on and off and nothing else. I have unplugged it and removed the battery and held down...
Remove the main battery and the power supply charger, allow a few minutes to get rid of any residual charge. Replace the battery, press power, if there is no change, remove the battery. Now plug the power supply back into the laptop, press the power, if it starts up the battery is bad and needs to be replaced.
Jan 13, 2011 | Gateway M-6750 Notebook
I turn it on and it makes the sounds of starting, no screen, it ran all night, I could hear that. now it just wont turn on the screen. Have I pushed a button or something wrong.
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jan 11, 2010 | HP Computers & Internet
My laptop was fine last night. i always use it on the charger but needed to take it off and use it. i did so and it ran out of battery so i put it on the charger but then it shut down. i just thought ill...
Remove the battery and mains adaptor. Press and hold the power button for a few seconds. Replace the battery and plug in the mains supply, press power for a few seconds and it should start up.
Aug 31, 2017 | Acer Gateway NV5814u Notebook
Compaq C500- Will not turn on no lights except for battery LED lit. It was working fine last night. The computer was left on and the battery ran down so it did not shut down correctly. When i push the...
Oct 22, 2009 | HP Compaq Presario C500t Notebook
Power light blinking
That is because either you screen is dead(test by connecting a exteral monitor) or you motherboard is dead and I have been seeing many dead motherboards as of late
Sep 19, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
Black pictures
Check your settings - could be if very black night, and you set it to 100 iso film speed, and maybe you are on say 1/1000 of sec at maybe f16, then that's ok. You would maybe need an explosion in an oil refinery to capture much.
However, you perhaps could try this:
1 change the battery for fresh one, and see if it helps - sometimes, the shutter won't really shut if battery power is very low
2. change the mode setting to auto, and see if the flash pops up and takes a pix - then if the pix is good, the camera is still working
3. Reset the camera to the factory defaults, by:
  • Firstly press the 'menu' button, then the up button above the 'OK' as many times as needed, until you see the top folders are highlighted.
  • Press the right button near the 'OK' until you see the last folder highlighted. You will know this is highlighted when you see the first menu option that says 'Language'. The 3rd one down from that says 'Clear Settings'.
  • Press the down button under the 'OK' until 'Clear Settings' is highlighted, then press the 'OK' button.
  • Scroll up to your choice and press 'OK' to reset your Canon 400D back to default factory settings.
If that fails, back to Canon! - good luck
Apr 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
JVC XV-511 Audio OK with CD but none with DVD
Walks' solution worked for me! Thanks lots! I was about to head to the repair store!
Nov 29, 2007 | JVC XV-511 DVD Player
Gateway MX6448 Notebook Logo
633 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
