there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Good luck.
That is most probably a faulty flex cable. this is a ribbon like cable that links the upper (screen area) and the lower (keyboard area). it usually develops cracks and some lines get cut off preventing the unit from displaying. solution is normally to replace it but you could also first have it checked to ensure that it has not simply gotten off the sockets (jacks). another link is here.
Regards
thank you, i will check it out later.and get back to you with results:gus
cables were lose,put them on.still no screen.cable may be bad ,will check further.thank you.
thank you i will give it a try:gus
thank you i will give it a try :gus
happy with this tech,to busy now to perform task.will get back to him at a later date,if that is ok. thank you :gus
