FF problem. Freezer fan problem: Check ice formation huge over freezer which blocked and restricted freezer fan to blow air into fridge compartment. Defrost manually by unplug the power. After some time, plug the power and check. And also check freezer motor is working and have no mechanical problem like struck. Helpful?
Samsung fridge freezer problems ..
have a look on you tube
srs2028 is same as the rs21 fault ... see this video
hope this helps ">
check ur air flow control assembly and ur cold control thermostat. You do hear the fan running right? if not u will have no circulation, also may want to check ur thermistors
