Maximum complaint in fridge is defrost problem. To solve :
First, you have to locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom or in theceiling of the fresh food section or behind the cold control cover. Once you locatethe defrost timer, slowly turn the screw like wheel in the middle of thedefrost timer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it. Thanks and hope helpful.
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Determine the temperature setting. The refrigerator should be set to temperatures ranging from 34 degrees to 40 degrees, while the freezer should be below 30 degrees. Adjust the temperature setting which will naturally improve the ice buildup that's been caused by the wrong temperature setting.
Move the refrigerator away from the wall. Oftentimes, this simple action is all that is needed because the unit is not getting enough air circulation behind it. Also, some refrigerators have vents underneath the unit, which are easily clogged with debris. Clean these vents and coils.
Remove food and shelving from the refrigerator and freezer portions of the fridge. If ice build up is happening in the freezer, the drain in the freezer may be clogged. With the unit off, remove coverings to expose drain and pour hot water down the drain hole until it comes out into the drain drip pan under the fridge.
Check the condenser coils. The evaporator coils could be causing the problem of ice build up. If this is the case, professional repair is likely needed to replace the motor, thermostat or other problems within the fridge.
Check this link for a detailed idea:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query or else please accept the solution.
Hi
This is usually caused by a clogged defrost drain. Many times vents between fridge and freezer sections are clogged with ice. Unplug the unit for 24 hours then plugin, and everything should work out.Also a faulty thermostat and Clogged/dirty evaporator coils (underneath in newer models, on back in older models) are the most probable reasons.Also All of the cooling in refrigerators is normally done in the freezer compartment. A fan circulates cold air from the freezer into the refrigerator compartment to cool it. Most likely this fan has quit working.
Please check the bellow link to have a detailed idea related to your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
