2004 Buick Rainier Logo
Posted on Jan 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Headlamp remove & replace - 2004 Buick Rainier
gord storey
Level 3:
  • Master 477 Answers
  • Posted on Jan 28, 2011
gord storey
Master
Level 3:
Answers
477
Questions
Helped
227350
Points
1540
If it is just burnt out , you do not have to remove or replace the whole lamp , just the small bulb inside of it. They are usually easily accessable from inside the engine compartment , and just come out of the back of the headlight by 1/4 turn.
michaelench
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 28, 2013
michaelench
Contributor
Level 1:
Answers
Questions
0
Helped
705
Points
6
The one thing that is different about this vehicle is that the front grill must be removed to replace the headlights. The grill is held on by clips and pops right off. After the grill is remove the head light covers will move so the lights can twist out for replacement. After the grill will snap right back on.
How do I change the headlight lense on my Chevy Trailblazer?
wow no year car told,why? 1998 to now, is it USA? car?
yes sold in S.America too, 2011 and up.
the outside casing lens?
the service manual covers this only
no problem told at all just how to. ( so I guess the whole thing out and in)
why skip saying the problem first.? to the blind.
is the front of the light casing all ugly and yellow?
2001-2008 (separate model, North America)
so I guess 2003, ( using ESP and Karnac mind meld)
replacing all this.??????
https://www.rockauto.com/en/catalog/chevrolet,2003,trailblazer,4.2l+l6,1412277,body+&+lamp+assembly,headlamp+assembly,10762
PULL steps
Headlamp Replacement (TrailBlazer) Removal Procedure
  1. Open and support the hood.
  2. Remove the grille. Refer to ' Grille Replacement (Chevrolet).
  3. Use a flat-bladed tool in order to release the clips that retain the grille to the headlamp panel.
  4. Remove the grille from the vehicle.
  5. Pull up on the retaining tabs?(1) in order to remove the headlamp assembly from the headlamp panel.
  6. Disconnect the headlamp leveling electrical connector from the motor/actuator if equipped.
  7. Disconnect the headlamp electrical connector?(2) from the headlamp assembly.
  8. Remove the side marker socket?(4) from the headlamp assembly.
  9. Remove the park/turn socket?(3) from the headlamp assembly.
  10. Remove the headlamp assembly from the headlamp panel.
if confused buy the service manual
or get the car serviced in real shop.
How to change a headlight on a 1997 gmc sierra
Headlamp Removal & Installation To Remove:
  2. Remove retaining ring screws.
  3. Remove retaining ring from headlamp.
  4. Remove headlamp from headlamp mounting bracket.
  5. Disconnect electrical connector from headlamp.
To Install:
  1. Connect electrical connector to headlamp.
  2. Install headlamp to headlamp mounting bracket.
  3. Install retaining ring to headlamp and install screws.
How do change low beam lightbulb on a 2007 dodge ram 1500
Removal & Installation-Get at it from behind the lens assembly.
These instructions show how to remove and replace the whole light assembly but shows a diagram
on what it looks like.
To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following: dod_ram15_02-04_headlmp.gif
    • Negative battery cable
    • Push pins
    • Bolts connecting headlamp unit to fender
    • Bulb sockets from headlamp unit
    • Headlamp unit
To Install:
  1. Install or connect the following:
    • Bulb sockets
    • Headlamp unit to fender with the bolts
    • Seal and push pins
Need help changing out the low beam on drivers side of 2006 buick rainier
Bulb Replacement
To Remove:
CAUTION
Halogen bulbs contain pressurized gas.
Mishandling a bulb may result in the bulb shattering into flying glass
fragments.
CAUTION
Make sure to wear eye protection when
handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb,
only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into
contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb
properly.
CAUTION
Do not allow children to handle halogen
bulbs.
  1. Turn the lamp switch to the off position.
  2. Make sure the bulb is cool before changing.
  3. Remove the headlamp assembly from the headlamp panel.
  4. Remove the rear access cover from the headlamp assembly.
  5. Disconnect the headlamp connector.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket
    counterclockwise.
To Install:
  1. Connect the headlamp connector.
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket
    clockwise.
  3. Install the rear access cover onto the headlamp assembly.
  4. Install the headlamp assembly into the headlamp panel.
Headlamp Assembly
Chevrolet
To Remove:
Headlamp Assembly (Chevrolet)
  1. Remove the grille from the front of the vehicle.
  2. Release the headlamp assembly retaining tabs.
  3. If equipped, disconnect the headlamp leveling motor connector.
  4. Disconnect the headlamp connector.
  5. Remove the park/turn and side marker bulb sockets from the headlamp
    assembly.
  6. Remove the headlamp assembly from the headlamp panel.
To Install:
  1. Place the headlamp assembly into the headlamp panel.
  2. Install the park/turn and side marker bulb sockets into the headlamp
    assembly.
  3. Connect the headlamp connector.
  4. If equipped, connect the headlamp leveling motor connector.
  5. Lock the headlamp assembly retaining tabs.
  6. Install the grille onto the front of the vehicle.
GMC, Oldsmobile, Buick, Isuzu, and Saab
To Remove:
Headlamp Assembly (GMC, Saab, Oldsmobile, and Buick)
  1. Release the headlamp assembly retaining tabs.
  2. Disconnect the headlamp connector.
  3. Remove the park/turn bulb socket from the headlamp assembly.
  4. For GMC, Saab, Oldsmobile, and Isuzu vehicles, remove the side marker bulb
  5. Remove the headlamp assembly from the headlamp panel.
To Install:
  2. For GMC, Saab, Oldsmobile, and Isuzu vehicles, install the side marker bulb
    socket into the headlamp assembly.
  3. Install the park/turn bulb socket into the headlamp assembly.
  4. Connect the headlamp connector.
1helpful
How to change headlight fo 2005 chevrolet uplander
Headlamp Removal & Installation Bulb Replacement To Remove:
  2. Turn the high/low beam bulb socket counterclockwise to remove.
To Install:
  1. Turn the high/low beam bulb socket clockwise to install.
  2. Install the Headlamp Assembly.
Headlamp Assembly (Park, Turn, Cornering and Side Marker Lamps) To Remove:
  1. Rotate the headlamp assembly retainer pins and pull up to remove.
  2. Remove the mounting bolts.
  3. Disconnect the harness connectors.
To Install:
  1. Connect the harness connectors.
  2. Position the headlamp assembly on the panel.
  3. Rotate the retainer pins and push down to lock in place.
  4. Install and secure the mounting bolts.
I have a 2003 Hyundia Elentra. I had a directional bulb fall out in the headlight case. How can I get it out?
remove the headlamp assembly (three 10mm bolts). Disconnect the wire harness connector to the assembly. Locate the bulb socket where the directional bulb fell out. Counter-clockwise, twist the bulb socket and remove from headlamp assy. Either return the bulb to its socket, OR replace the bulb & re-insert the socket into the headlamp assy. Reinstall the Headlamp Assy.
How to replace headlight bulb on 2002 chevy trailblazer
CAUTION
Halogen bulbs contain pressurized gas. Mishandling a bulb may result in the bulb shattering into flying glass fragments.
CAUTION
Make sure to wear eye protection when handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb, only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb properly.
CAUTION
Do not allow children to handle halogen bulbs.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket counterclockwise.
To Install:
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket clockwise.
Headlamp Assembly Chevrolet To Remove:
  5. Remove the park/turn and side marker bulb sockets from the headlamp assembly.
To Install:
  2. Install the park/turn and side marker bulb sockets into the headlamp assembly.
6helpful
3answers
Change low beam
CAUTION
CAUTION
CAUTION
CAUTION
CAUTION
CAUTION
To Install:
How do i change both headlights on my 2002 chevy cavillier
  1. Remove or disconnect the following:
    • Hood close out filler panel.
    • Bolts from the headlamp.
    • Headlamp from the headlamp mounting panel.
    • Electrical connector from the headlamp.
    • Headlamp bulb/socket retainer ring from the headlamp.
  • Headlamp bulb/socket from the headlamp.
  • Bolts from the headlamp adjuster mechanism.
  • Headlamp adjuster mechanism.
  • To Install:
      • Headlamp bulb/socket to the headlamp.
      • Headlamp bulb/socket retainer ring to the headlamp.
      • Headlamp adjuster mechanism to the headlamp housing, if necessary
      • Bolts to the headlamp adjuster mechanism. Tighten to 6 N.m (53 lb in).
      • Electrical connector to the headlamp.
      • Headlamp to the headlamp mounting panel and lower mounting bracket.
      • Bolts to the headlamp. Tighten to 10 N.m (89 lb in ).
    Top Buick Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Buick Expert? Answer questions, earn points and help others
