Dehumidifiers Logo
Posted on Jan 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The light comes on that it is full but will not turn on power. This dehumidifier is not new but did work last winter and is fairly new.
  • Mike Butler
    Mike Butler Jan 28, 2011
    If it's full, and not automatically draining water out to an alternate spot, then it needs to be emptied. If it has a tub inside or under that needs to be emptied because it's full, then that's probably why it won't come on, it's a safety so that it doesn't overflow onto floor.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 247 Answers
  • Posted on Jan 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
247
Questions
0
Helped
70113
Points
574
Check the main PCB board if has burn connection check fuses if ok if not replace new one on pcb board connect with wire the burn out connection or replace new one.check the resistance of motor & compressor if good using ommeter.
1helpful
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
My dehumidifier says the bucket is full, when it is empty. the red light flashes and it beeps. I can't get any buttons to work. I have taken the bucket in and out several times. Any suggestions? It did...
First, the unit may need to be cleaned and after that, unit may need to be reset. Turn the Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. Then plug it back in and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that 12 - 15 minute timeout, allowed the electronics to reset themselves. If this continues to occur frequently, contact an authorized Frigidaire Service Center
Hope this helps you troubleshoot and solve the problem.
HDN455 worked fine last fall. Turned off for winter. Started this week. Sounds and runs fine but not a drop of water condenses. Coils are not frosted over. Unit is warm along bottom. Air discharge is at...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Dehumidifier doesn't draw in water (humidity).
It may be too cool in the basement for it to work. Mine doesn't work if its 67 or below. Take it upstairs and see if it works there, where it is warmer.
Dehumidifier goes off after winter break
There are two reasons that it should turn off. Either the humidity level is at the setting off the humidistat control switch or the bucket is full. The only other thing I can think of is that the motor is overheating.
Full light comes on early
Most dehumidifiers rely on a float sitting in the pail to rise, turning off the switch. Check and see if the float moves clean and smooth, and is sitting in the pail rather than resting on it's brim.
There may be other safety switches, like a temperature sensor to turn it off if it runs the risk of freezing up or overheating.
Dehumidifier
After reading comments and complaints from other frustrated Maytag owners, I just went out and bought a new LG EnergyStar dehumidifier. I'm taping the receipt inside a plastic bag, along with the user manual, to the side of the machine. Hope this one works for a LONG time! Ronnisue
2helpful
2008 Frigidaire 50 pint Dehumidifier from Lowes
You can test it out by disconnecting the power cord, wait five minutes and plug it back in. If it retains the original settings you are good to go. If you are wondering before purchasing a new unit ask before you buy.
Top Fedders Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
