Question about Panasonic TH-42PZ77U TV
My tv blinks 10 times as well but im not sure on the power supply part number.
  • 135 Answers
High voltage problem
Posted on Apr 20, 2012
    President:
  • 1,335 Answers
Check with Panasonic support at
http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/Operating-Instructions/model.TH-42PZ77U.O#ts
They can give you the part number for the power supply or any other part for the TH-42PZ77U TV.
Posted on Jan 28, 2011
6ya staff
SOURCE:
How do I fix this.panasonic Viera tv power supply issues.?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Feb 13, 2016 | Televison & Video
I have a 2009 panasonic tcp50x1 plasma tv and im getting a 10 blink error code. Is that the main board or power supply board issue?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Panasonic TCP50X1 TCP50X1 50"" Plasma TV
My TV does not power up,Sony KDL-52XBR9,it tries to trigger the relay on power supply board G7N 4 times(RY6101) then it turn to blinking red LED 10 times per cycle.Is it power supply fail?which part?
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 12, 2015 | Sony KDL-52XBR9 52 in. LCD HDTV
Light blinks 10
if it's a panasonic repair or replace power supply you should listen carefully of the number of clicks from relays.when you first push power,two clicks followed by a third within 3 to four seconds.if you don not hear the third :) its the power supply.hope this helps
Jun 28, 2014 | Televison & Video
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here slinteriors@yahoo.com
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
I have a Panasonic Plasma, th-50px60u. The power button blinks 10 times pauses 3 seconds and then blinks 10 more times. I got some direction to replace the tnpa3761 board. That has not solved the...
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout,,,,,,
Aug 04, 2010 | Televison & Video
Will not turn on, power light blinks 10 times, pauses and then blinks 10 times.....
There are likely two separate power supplies in your set; one main supply and probably an additional high voltage supply required by the plasma display. The 10 blinks probably are telling you which but only the maker or a tech familiar with this set would know. You might try calling a Panasonic service center in your area and they can surely tell you with the model number and blink count.
Feb 13, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Power light blinking 10x
It's not necessarily the power board. 10 blinks is the Miscellaneous error code. Your TV knows something is wrong, but isn't sure what it is. It can be any number of things, including bad boards. Mine, personally, was multiple bad boards.
Dec 22, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
Panasonic TH-42PZ77U TV Logo
918 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
