Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem
You need PC suit software provide by SAMSUNG
To use your phone as modem
*install the pc suit software
*Open PC suit and select "Connect too internet"
*if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list and try to connect now.....
2)you can use Bluetooth technology to connect to internet
For this you need
*Bluetooth on your PC and phone
To connect(in windows OS)
*Click on Bluetooth symbol on task bar
*Select add device select from device which can be connected to your pc list(set your bluetooth device to visible mode)
*Add your device to your pc
Add completion of the above...
*Again click on bluetooth symbol on task bar
*Select "show all devices"
*now select your device(one click) at this time 4 options appears on top your devices list
*select connect using>access point
and 2nd method is *Again click on bluetooth symbol on task bar
*double click on your device
*select connect to internet from the dialog box which appears after selecting the
your device
Thank you
