Hello
Just set it to factory defaults first. Setting it to cactory defaults, will reset all the items except picture settigns. Parential password will also be get resetted. You have to set it later. To reset the TV to factory defaults, do the following.
[1] Push Menu button and select Setup.
[[2] Select Reset To Defaults from the drop down window.
[3] Push OK button.
The TV will reset to factory defaults and will display it. After that it will switch ON again. Ok
did you not see what I said there is no menu!.... tech told me it was the power supply, replaced it twice, same result... WTF is going on, no one can help and the Renter insurance can't replace cause no company can tell me what is wrong and give me estimate that is at least the amount i payed minus the the deductible.....
Hello
Every TV must hanve its own Menu. From that menu option, we goes to the other sub options like picture control, advance controls and so on. If the remote control does not have the menu button, there must have an other button that does the job. Only markings will be different. But that button will do the same action. Just try and find out which button does the job, and consider as the menu butoon, and go on. OK..
It's been A while since I messed with thing........ I don't think you understand. Sure there is a remote control and there is a menu button on the TV, but you can't access the menu on the screen when pushing either button. Original Post: " tv turns on but no picutre, no menu....." the TV has power, just cycles on and off, no blinking indicators...NO IMAGES on the screen... tech support over the phone can't diagnose and in home tech said it was the power supply.... I replaced Power supply... Still the same issue on for 30 seconds shuts off and then back on, no picture no menu.......
Replace the mammory IC. This Ic an be located very near to the main system contorl section, close to the system IC. It is an 8 termimal IC, out of which four of its terminals will be connected to earth [negative] , one meant for +ve supply [5VDC], one for seirial data, and an other for serieal clock. Usually one pin will be connected either to negative or left unconnected {free}. The IC is not so expensive too. Replace it. Display and other are related to this IC. OK.
Great... that sounds like a plan, i'll take it apart again this weekend and see if I can locate and execute.. any thoughts on a place to order the part (IC)?
This must be the fault. Replace it. I'm sure that this will solve your TVs problem. OK.
