Tanita Digital Body Fat Scale with 2 Memory Logo
Posted on Jan 29, 2011
Someone has switched my tanita BF 625 to metric readout and i don't know how to switch it back
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
540
Points
Press the set and arrow UP button at the same time. Then use arrow UP to find lbs. Press the set button to confirm.
My Tanita mini scale model 1479j2 says err 7 when I turn it on and then it turn rite off rite away what’s the problem anyone can help me I don’t know what to do
Does it work if you turn it off, then wait 15 seconds, then turn it on?
Your question specifies on off quickly
When you cycle the power switch quickly sometimes the electronics do not get the chance to discharge, leaving erroneous data in the buffer. If the unit otherwise operates OK, then just make sure you pause between switch operations.
What does the Error code -0L mean on my Tanita BF-679
OL is 'OverLoad!
• "OL" appears while measuring. Reading cannot be obtained if the weight capacity is exceeded.
BF-679W/BF-680W - Tanita
Tanita https://www.tanita.com > .downloads > download PDF This Body Fat. Monitor/Scale passes a low-level electrical signal through the body, which may interfere with the operation of a pacemaker. • The Tanita Body Fat ...
How to zero Tanita scales
Thermostat switched to Metric readout on its own, how do I change it back?
if your talking about centigrade instead of farenhight hold the + & - down at same time it will switch back
1helpful
Error code r5 on Tanita BF-350
Just spoke with Tanita Tech support- r5 indicates if the scale is in PC mode (able to receive data from scale). There is a button sequence to toggle between PC mode and stand-alone mode.
1. Press&Hold Zero button, then Press&Hold On/Off.
2. Release.
3. Arrow buttons toggle between PC mode and Stand-Alone, select which mode you would like.
4. Press Set button to select mode.
Hope this helps!
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
8helpful
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
78helpful
3answers
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Method 2
64helpful
3answers
Scales show weight in kg. How to get them to show lbs.
1helpful
Measurement is in kilograms instead of pounds
check if there is a tiny whole in the back you could probably poke it with a needle
Top Tanita Health & Beauty Experts
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
