The Denon RC-1068 universal remote has an Amp button on the top left side of the unit. This button toggles through Amp, Zone 2, Zone 3, Zone 4 (on some devices) and System Call. In the Amp mode, it will control your Denon device default zone. If the remote is set to one of the other zones/modes, press the Home button (right side in the row with the Quick Select keys, above the surround sound buttons) to return to the Amp mode. Then press the Input button (on the left side), below the tuner buttons, to select the audio-visual source that you want.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
My self have problem with Denon AVR 3808Ci Receiver, the HDMI is doesnt work anymore, and I can not find replacement parts because receivers is out of date, very shame
Hello
Nickel-Cadmium battery will have a voltage of 1.2V. Four cells together with in series connection give you 4.8VDC, The number 8000 on Denon battery denotes, that it has a current rating of 8000ma [milliampere]. Most of the Ni-Cd batterys will have the same rating. You can use any company's prodcut, provided the size should be the same. That is all. Some battery packs will have 1 ampere capacity, can be used in place safely. No problem at all. OK.
