Question about JVC AV-56WP30 56" Rear Projection Television
Red bar on bottom of screen
Hi i have JVC model#av56wp30 the convergence went bad and technician fix it but about 3 inches in the bottom is shadow flat red from left to right and the rest of the screen little bit of red shadow i can move the convergence but in the bottom the the red x of the convergence is bigger than the rest
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: red tube is projecting wide (convergence)
You need to replace the convergence IC's
Posted on Jun 08, 2006
Anonymous
  • 203 Answers
SOURCE: convergence no good on lower corners and upper screen
What you're actually seeing is what the TV looks like without any convergence. I would also suggest replacing them with the 392-150 as they are better at handling the current. If the new STKs don't fix the issue then you may have another issue on the convergence module
Posted on Jun 09, 2007
Anonymous
  • 9 Answers
SOURCE: JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Posted on Aug 18, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 28, 2008
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: JVC 56wp30 convergence
Convergence amp ic bad
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Jan 31, 2008
I cannot adjust the # 1 and 2 + to line up in my color convergence. The green one is lopsided and too far down on my JVC 56 inch AV56Wp30
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 10, 2011 | JVC AV-56WP30 56" Rear Projection...
I have a JVC TV probably 10 years old 50 inches and I see the images on the screen like if I have 3 D all the figures are double exposed in red
This is an indication that your convergence gone bad. This is very common in older unit like yours. Look for a qualified technician to adjust the convergence manually.
Thanks for using fixya.
Feb 01, 2011 | JVC Televison & Video
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
Model 50UX58K - picture has distortion & shadow on right side of screen
Hi, if the shadow is colored lines then you probably need the convergence ICs and possible reisitors near them replaced .
If the shadows is just like a ghost of the image or a bar from top to bottom, then check if it does it on every input (dvd for example) , there are blanking bars that you can't see past the edges of the picture and when you have a bad cable signal you can see the ghost of the blanking bar sometimes. if it does it does not show the shadow when watching a DVD then its a signal issue with your cable/satelitte .
If your convergence is the issue, try the adjustments first and if that doesn't correct it, you can replace the ICs using kit # x480293 or stk392-110 (2 ICs) soldered in very technical for even a technician.
repairman cost about $250-$350
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 01, 2009 | Hitachi 50UX58K 50" Rear Projection...
My 56'' jvc av56wp30 tv screen is doubled only twords top o screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 19, 2008 | JVC AV-56WP30 56" Rear Projection...
Double picture
*Screen Looks 3-D
*Colors wont align
Aug 31, 2008 | JVC AV-48WP74 48" Rear Projection...
Red and green shadows
Your tv has a convergence board problem. Have a technician replace the convergence IC's.
Jul 08, 2008 | JVC AV-48WP30 48" Rear Projection...
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
Sony Convergence
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
JVC AV-56WP30 56" Rear Projection Television Logo
57 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
