There will be 2 wires in different colors inside the cable,
these wires are enamel coated and sennheiser has best quality coating over the wires, so soldering this could be a bit messy - this is the procedure to do so
first take out these wire leads out for about a centimeter from both the ends, try to loosen the leads and yo will find small clustered strands of fiber wound between the leads try to remove those fibers (only the visible ones) completely from both the ends of the exposed leads.
take a blade and try to wipe out the enamel coatings from the wires (make sure that the 2 leads does not touch each other after removing the enamel) now connect (solder) both the ends of the wire with their respective leads (eg. red with red or green with green as applicable) now you should be good to go
Please understand this is a delicate job and require atmost attention use cello tapes wherever applicable and tie knots at correct places to avoid further damages
