Nintendo DSi Matte Blue Console Logo
Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 051099"1 nintendo dsi.trying to get
William Dehn
Level 3:
  • Master 318 Answers
  • Posted on Jan 30, 2011
William Dehn
Master
Level 3:
Answers
318
Questions
0
Helped
112856
Points
1021
Error Code: 051099Was this information helpful?
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
Here's a link:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
DONT FORGET TO RATE THIS PLEASE
Nikki Mclean
Level 2:
  • Expert 293 Answers
Nikki  Mclean
Expert
Level 2:
Answers
293
Questions
Helped
88146
Points
891
Hi mcgck2
PLEASE RATE MY ANSWER IF YOU FIND IT HELPFUL !
At this link you can find all the info you need on how to connect your DSI to wireless internet...
http://www.nintendo.com/consumer/wfc/en_na/ds/connection.jsp#router
error code 051099
No access point in range error code 051099-1
  1. Create a new connection:
  2. Trying to play online multiplayer with Nintendo DSi
  • Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
  • Scroll over to the third page, and select "Internet."
  • Now choose "Connection Settings."
  • Click on "None" for "Connection 1."
  • Click on "Search for an Access Point."
  • The Nintendo DSi will search for any wireless networks within range
  • What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
for more help visit https://cbrtechsolutions.net
1helpful
I can't get my nintendo dsi to connect to the internet keeps coming up with error code 051099 - 1
There's some kind of incompatibility between your hubs settings such as the name or security settings that is incompatible with the dsi.
have a look at this website and let me know if you've solved the problem
http://www.nintendo.com/consumer/systems/dsi/en_na/usb/index.jsp
9helpful
Trying to connect to the internet: Error code:051099-1 also I am trying to get some pictures off the DSi to my labtop.
Your wireless router may not be compatible with the DSi. You can check here to see if your router is on the list of compatible routers.
4helpful
Error code 051099-1
This is a wireless setting problem, follow the instructions on Nintendo's site to fix: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099-1&system=DS&locale=en_US
1helpful
4answers
Internet access on the nintendo DSI is saying no compatible access point in range check your connection settings under the internet option and try again error code 051099 we dont know the ssid code to...
The nintendo dsi needs a wireless router transmitting in MIXED mode, meaning that it transmits using B mode as well as G or for newer routers N mode. If it is setup to transmit in G or N only, then the DSI will not detect it.
Also, the DSI is not compatible with WPA security. You need to set up a weaker WEP security code or turn off wifi security altogether.
Also, make sure the router is broadcasting the SSID name which is the name of the wireless router.
for more information: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099&system=DS&locale=en_US
I can not connect to the internet it keeps saying error code:051099 -1
Error Code: 051099 This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
Cannot connect to internet
If after trying the steps above you are still receiving this error code, please call 1-800-255-3700 for further assistance.
Error code : 051099
1helpful
DSI WILL NOT CONNECT TO WIFI ERROR CODE 051099-1
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
