Toys Logo
A
Anonymous Posted on Jan 30, 2011
I just had this Valor g4 installed yesterday. First of all, when I use the remote to turn it on, does the setting have to be in "temp" position on the remote?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
862
Points
5
No, I have mine in manual mode, then hit the red (off) key and large flame key ( top right) at the same time. You should hear a click followed by a series of clicks as the pilot light turns on and then the gas valve opens and it should light. Having said that, I happen to have two that were installed at the same time. Unfortunately one has a bad remote control. I found that out after switching and syncing the remotes to the other insert. The good remote works on both and the bad one on neither. The bad remote would not let me set the time.
My Trane thermostat (TCONT600AF11MAA) is supposed to have 1.5 degrees of heat pump "rest" above the desired setting before turning on the heat pump. The thermometer reading does not change yet...
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
Put together starter system need a diagram on a valor tropic 121 wall gas fire
You should be able to download the installer instructions on
Valors website, the information can be found here
under Trade then installer guides
www.valor.co.uk
alternatively new Valor Gas Fires
Jan 02, 2011 • Valor Toys
My programmable thermostat current temp reading is 65 but my temp is set to 68. I noticed it yesterday also (read 66), and this is not normally the case. The "current temp" setting is normally...
What type of system do you have, Heat pumps have an AUX setting if that not comming on depending on where you live it may not keep up on its own. A gas furnace should give no trobble check you normal stuff like the filter and it is not on a program and changing over around the time you check it.
How do I turn it on? I press the "on" button and
The manual says:
http://www.coinwash.com/temp/rinnai.pdf
"For the name of the Authorized Distributor or Installer nearest you, please contact your local HVAC dealer or gas service technician, visit the Rinnai website (www.rinnai.us), call Rinnai at1-800-621-9419 or write to Rinnai, 103 International Drive, Peachtree City, Georgia 30269"
Manual says that the remote is for setting temperature.
When you turn on hot water spigot, tankless water heater will heat the water to the set point temperature.
If water heater is not set up to use remote, then tankless unit will heat to 140 degrees F.
"With the MCC-45-4US remote control installed the water temperature is adjustable from 96
to 180°F. The water temperature cannot be set to a temperature other than 140°F
without the use of the MCC-45-4US remote control unit. If you require a temperature
other than 140°F you must install the MCC-45-4US remote control unit."
"Error messages are displayed on the remote control units, simplifying service calls."
Page 9 of manual shows hot to set temperature using remote.
Water taps must be shut off to set temperature.
Circulating pump must be turned off.
"Simply press the H or C button until desired temperature is displayed"
"green in-use indicator will display"
If your unit is not working, the manual says to contact local plumber.
Fixya has specialists who will talk to you by phone about your problem for a fee.
New Mr. Slim system just installed. Set to "Heat." Temp setting adjustment on the remote control will not go below 59 degrees. Is that factory setting? Set at 59 it keeps room at 70 degrees,...
I have a related concern. I put the Mr. Slim unit in my garage/workshop and most of the time need it just to keep the pipes from freezing. I'd like to set it at 45 or 50 degrees, but the lowest it allows is 59. I bought this to save energy, but it's forcing me to keep the room warmer that I'd like.
V6 2008 1/2 ton PU 2wd "Engine temp high/AC turned off " display. Temp guage shows 160 deg , fans running constantly , heat from vents normal. Coolant expansion tank full , oil level full...
160 is not high-thats below warmup temp--the fan sensor has issues etc Vehicle is not gettin to operation temp so hav it diagnosed for free at a parts place-fan motor may be goin bad
Top Valor Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Valor Toy Expert? Answer questions, earn points and help others
