The frost build up is causing airflow blockage to fresh food compartment. Frost build up is either a sign of poor door seals, door left open, or bad defrost circuit. If after manually defrosting and after a few days the frost reappears, problem most likely is with the defrost circuit.
If you have some background of electrical circuits you may attempt repair yourself or call in a tech.
Defrost timer on your unit is near the light in the refrigerator. Recessed in a hole, turn with a flat blade screwdriver and advance timer until you hear a click and refrigerator turns off. After a few minutes the heater should come on and should hear moisture hitting heater in freezer compartment in back panel.
If heater is not coming on, could be a bad heater or defrost thermostat is bad. Both of the parts are accessed through the back panel inside of heater. Unplug and ohm check for continuity of heater & defrost thermostat. Heater is a cal rod unit, thermostat more likely to be the problem. part #5303918202
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
