WHen the picture appears fuzzy, see if the problem persists on the no signal screen. It sounds like a tuner issue or LCD controller problem, and we have to find out which one of them it is.
Even on a dark screen the fuzzy picture is noticeable though you have to look close. If you do not see anything then rest assured that this is a problem with the signal procfessing circuits. You are gonna have to replace the main audio/video board to fix this. If you would like me to find you a replacement board, then please remove the back cover and get me the part number off the board that has all the inputs.
No thats not it. Please get me the model no of the set so that I can tell you where to find it and what the number sequence looks like.
The part number will be something like 55.73D01.021G
See if you can find something like that. Do not miss the dots.
That is not the main audio/video board. Its the IR board. By inputs, I meant audio/video inputs, not the input buttons at the front
Yes in some tv sets it is covered by a large metal plate at the center. No problem get me the part number when you have time
can`t tell in the no signal the screen is dark
part# 5604264001G 706 01888 BL 05
SK 32H240S
I was looking at the big board there`s a small board at the bottom with this #55.3ys02.001g 1a
i have to take off appreciate your help anyway its probably under another cover donn`t have time right now. thanks
