Probably need to replace rollers. There are two at the back of the drum, and depending on the model tehre might be two at the front of the drum. It should be pretty obvious which one is the problem, it will either be really loose, or have a flat spot.
Testimonial: "thankyou for the information i will check it outthat sounds like the problem once again thanks."
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
