SAMSUNG BN44-00342B = BN44-00342A I55F1_ASM POWER SUPPLY / BACKLIGHT INVERTER https://www.abctay.com/samsung-bn4400342b-bn4400342a-i55f1asm-power-supply-backlight-inverter-p-2533.html
Is it a Samsung LN55C630? if it is it may be your power supply board BN44-00342B hope this helps
If you have another TV then you can swap it. See if the problem goes away. Of if not start with the cable. Make sure the heads are professionally placed on and not done by hand. You can get short cables from Radio shack that could help in tracing this out. Also you can try another wall outlet.
Thanks and good luck,
Shawn
I'm sorry that the picture on the TV has constant flickering. Please follow the troubleshooting steps and check the operation:
