Lexmark T630 Laser Printer Logo
Posted on Jul 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 929
Dear Sir,
Would you let me know this error code 929 meaning?
Which parts need to replace with parts #? Thank you in advance.
by tony
Anonymous
Level 2:
Scholar:
  • Expert 191 Answers
  • Posted on Jul 20, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
191
Questions
0
Helped
84367
Points
496
I have an error code CD 40 on a Toshiba estudio 2540. Do you know what this code means. Thank in advance. Joe
Do u mean CE40? Because there is no CD40 error code...
CE40 is image control related service call where the image quality control test pattern abnormal.
Image quality control abnormal detection display/0 clearing
08-2528 Y
08-2529 M
08-2530 C
08-2531 K
From above u know which process unit giving problem, then further check the main charger, developer...
My Power First T960 stopped whilst I was using it and come up with an E1 error. I have lost my users guide so I don't know what this means. Help please!!!
Dear Sir:
I will help you inmediately, do not go in panic:
1) Check is voltage is o.k 115VAC, measure with a VOM(Voltimeter)
2)Try again, if is working. If donot check the c. breaker or fuse.
3) Is everything is o.k the faulty is VSD(Variable Speed Drive) the give the ERROR I.
4) That means the VSD is defective, try to put some special liquid for to clean Pot or contact, and check again.
5) If not you must return the PCB, to the factory indicating the Code ERROR for to fix easy.
Thank you in advance , blessing , sincerely.
E.CUADRA
MANAGUA, NICARAGUA C.A.
15helpful
4answers
2005 FORD TAURUS WITH 43,000 MILES...ENGINE LIGHT JUST CAME ON...IS THIS AN IMMEDIATE ACTION ON MY PART?
I think the problem is from the Emission System, something must have gone worng with it. and sometimes it is necessary to check the O2 Sensor as well. But it will be better you scan your car with the computer and so as to know where the problem comes from, so the error code from the scanning will now indicate the repair to be done on your car. Kindly take your car to an Auto Service Center to retrieve the error codes and then ask then to repair it for you or you forward the error codes to us so as to know the best repair to be done on the car. Thanks
22helpful
5answers
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
PERMANENT RED LIGHT pls, the light close to the meter is showing red light. that is the human being shape and the round sign
Hello sir; Is there have error code display on screen? if not means need periodical service,( need replace drum, cleaning blade, developer etc.).
CODE C39 ON TOSHIBA 211C
C39 = Auto toner initializing error
Check toner supply
Check toner motor
Check TD sensor
Replace transfer unit
2helpful
2answers
STAUS INDICATOR SHOWS "L-6" ON SHARP AL-1010
Dear sir; The L-6 error code it means "laser drive, motor", It can be reset, the procedure as follow;
1, press "clear", "exposure mode", "clear", "exposure" those keys.then machine go dead.
2, enter 14, then press print.follow the direction willtake car the problem.
If you need more help just let me know I'm always around, or generously give me good rating. thank you,
HAVE A MERRY CHRISTMAS !!!
1helpful
Error l4 02 in sharp ar5132
Dear sir;the error code you ask about for sharp copier, it means drum motor problem, why don't give them a try to reset before go to replace it, the procedure is
1, press "clear", "pause", "0", "pause"key
2, press 14 then press start.
Have anymore question, please let me know,
HAVE A HAPPY HOLIDAY !!!
8helpful
5answers
Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
