SOURCE: Conversion of Professional headset to use with a computer
you must use microphone pre-amplifier prefer mb-7---you will connect your mic to pre-amp in and take pre-amp out and connect in computer line in-adjust software for line in audio.
SOURCE: How do you get a sennheiser RS 130 headset to work in a computer?
i told u so kayla. a sound card upgrade is necessary so the connection would work.
plz rate!
SOURCE: Sennheiser MM 50 iPhone Mic & Button does not work
I had just the same problem and if you're lucky, the solution is very simple: due to the open headset-plug of the iPhone I had a lot of dust inside. Just try (carefully!) to get the dirt out of the jack with a pair of tweezers or a strong vacuum cleaner. In my case it solved the problem. Good luck!
SOURCE: Sennheiser VMX100 not working with G1
make sure you oreder your bloothoth from htc and its for the g1 next time
