As long as the set is mounted correctly, there should be no real trouble with heat.
The Mounts, are/maybe standard, however it is the fastening that will differ, if stone, brick, concrete then special fixings must be used, apart from that you will be all good.
Yes,does the heat reaches 100-110 or more than hour for the wall where the tv area,to mounted?The tv electronic can be also malfunctions quickly before it times and the plastices frame will become more briddles can and will causes the tv come off it mounts and drop and destroy the tv.
Unplug the power cord of the receiver box for 10 seconds and then plug it back.
