Does this help?
If you wish to prevent small children or pets
from climbing into the machine, you can
deactivate the automatic door opening
function.
1. Turn off the machine using the main power
switch.
2. Press the Door Open button while
simultaneously pressing the main power
switch. Release the buttons.
3. Press the Key button and the red field goes
out. Automatic door opening is now
deactivated.
4. Press the Start/Stop button to save the
setting.
If you want to reactivate the function, follow
the instructions above, but when you press
the Key button (point 3) the red fields light up.
Store the setting by pressing the Start/Stop
button.
Do let us know if it does
regards
SOURCE: child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
SOURCE: need to disable child lock
If you didnt lock the unit yourself - the ECU is failed and needs replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: child lock and spin/end lights on and stuck need to reset
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
