Gameplay (basic)
The goal of the game is to be the first
fairy to water any flower with 3 water droplets and make it bloom. You
move your fairy around by tossing the dice. Each player tries to reach
their butterfly bridge (with the color of the butterfly matching the
color of the fairy), enter it and then reach the water pool. After
reaching it you press the lily leaf above the pool and collect the water
droplet. Now it's time to get to the flower which matches the color of
the droplet (unless it's gold - then you can water any flower) using the
same bridge you entered the pool. The game is over when the first
flower is fully bloomed (after watering it 3 times) and everyone wins,
because everyone help watering the flowers.
The interesting twist
of the game is the dice, which has 1, 2, 3, 3, 4 and 90-degrees sides.
The last one is used to rotate all bridges 90 degrees forwards or
backwards, which may help you in watering the flowers faster.
Gameplay (advanced)
This
time the goal to be the first fairy to water YOUR flower with 3 water
droplets and make it bloom. You move your fairy around by tossing the
dice but only clockwise. You also have to use your own butterfly bridge,
but after you collect the water droplet the rules become different. You
have to use the bridge which matches the color of the droplet you
collected (unless it's gold - then you can use any of the bridges) and
then travel to reach YOUR OWN flower and water it. After you go back and
forth and water the flower 3 times you win the game.
The dice is
used in exactly the same way, but now it's used to either help your
cause or screw your opponent. You are also allowed to use two different
kinds of cards. At the beginning of the game you get 3 flower cards and
may use each of them once to get additional movement (or turn the bridge
around). There are also leaf cards, which you activate by finishing
your move on a leaf symbol - they also accelerate your movement in
several different ways.
